Ir para o conteúdo principal
Cobra MR HH350 FLT Screen Replacement
O que você precisa
  1. Cobra MR HH350 FLT Screen Replacement, Battery: passo 1, imagem 1 %32
    • Remove the 11mm screw at the bottom of the radio with a #4 flathead screwdriver.
  2. Cobra MR HH350 FLT Screen Replacement: passo 2, imagem 1 %32
    • Remove the battery from the radio.
  3. Cobra MR HH350 FLT Screen Replacement, Motherboard: passo 3, imagem 1 %32 Cobra MR HH350 FLT Screen Replacement, Motherboard: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the 6 rubber stoppers using tweezers to reveal screws.
  4. Cobra MR HH350 FLT Screen Replacement: passo 4, imagem 1 %32
    • Remove the 6 10mm screws that were behind the rubber stoppers with a #0 Phillips screwdriver.
  5. Cobra MR HH350 FLT Screen Replacement: passo 5, imagem 1 %32
    • Remove the cover to expose the motherboard.
    • Pull off the power nob at the top of the radio.
  6. Cobra MR HH350 FLT Screen Replacement: passo 6, imagem 1 %32 Cobra MR HH350 FLT Screen Replacement: passo 6, imagem 2 %32
    • Remove the 2 6mm screws on the motherboard with a #0 Phillips screwdriver.
  7. Cobra MR HH350 FLT Screen Replacement: passo 7, imagem 1 %32
    • Remove the motherboard.
  8. Cobra MR HH350 FLT Screen Replacement, Screen: passo 8, imagem 1 %32 Cobra MR HH350 FLT Screen Replacement, Screen: passo 8, imagem 2 %32
    • Now that the motherboard is gone, the back of the screen is now accessible.
    • To remove the screen, you need to use the Jimmy in the IFIXIT tool kit. It may take some time due to the epoxy used to keep water from entering the device.
Conclusão
Rajahn Lewis
Membro desde: 09/15/23
145 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 49
