Ir para o conteúdo principal
ClickN Kids Tablet Touch Screen Display Replacement
O que você precisa
  1. ClickN Kids Tablet Touch Screen Display Replacement, Touch Screen Display: passo 1, imagem 1 %32
    • Start on the side with the camera. The screen side is black, the back side is colored
    • Insert a plastic opening tool into the space between the screen and the back side.
  2. ClickN Kids Tablet Touch Screen Display Replacement: passo 2, imagem 1 %32
    • Press the plastic opening tool in until you hear a “click” and that part of the tablet opens.
    • Press and slide the plastic opening tool around all sides of the tablet until all sides pop off.
  3. ClickN Kids Tablet Touch Screen Display Replacement: passo 3, imagem 1 %32
    • Lift the detached screen from the camera side until you can see the inside of the tablet.
    • Potential for device damage. Don't open too fast, or you might damage the ribbon cables.
  4. ClickN Kids Tablet Touch Screen Display Replacement: passo 4, imagem 1 %32 ClickN Kids Tablet Touch Screen Display Replacement: passo 4, imagem 2 %32
    • Potential for device damage. Be careful not to damage any wires or ribbon cables during this step.
    • There are two ribbon cables to remove during this step. Each is connected to a base on the motherboard.
    • There is a black tab behind the long ribbon cable. Lift up the black tab.
    • For the ribbon cable in the back, pull the black tabs on the side out.
    • Detach the ribbon cables connecting the screen to the motherboard.
    • Remove any tape that is holding down the ribbon cables. Set it aside.
    • Once the ribbon cables are freed, separate the top and bottom sides.
  5. ClickN Kids Tablet Touch Screen Display Replacement: passo 5, imagem 1 %32 ClickN Kids Tablet Touch Screen Display Replacement: passo 5, imagem 2 %32
    • Remove the yellow tape on the right side. Easiest side to get.
    • Remove the black and yellow tape stuck together on the left and bottom sides of the screen.
  6. ClickN Kids Tablet Touch Screen Display Replacement: passo 6, imagem 1 %32
    • Potential for device damage. Make sure the screen is facedown and level to prevent or reduce damage to the display.
    • Potential for device damage. There is an adhesive on the top edge of the display’s face. Be careful not to damage the display.
    • Flex the sides of the tablet until the clips holding the display to the screen case pop loose.
  7. ClickN Kids Tablet Touch Screen Display Replacement: passo 7, imagem 1 %32 ClickN Kids Tablet Touch Screen Display Replacement: passo 7, imagem 2 %32
    • Be careful not to damage the display or screen case.
    • Pull the display from the top side to detach it from the screen case.
Conclusão
4 outras pessoas executaram este guia.
Kevin Finney
Membro desde: 03/22/15
562 Reputação
Autoria de 4 guias
Equipe
Baylor, Team 4-4, Williams Spring 2015 Membro de Baylor, Team 4-4, Williams Spring 2015
BU-WILLIAMS-S15S4G4
3 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 15
Ao todo: 8,148
