Introdução
If you are having trouble adjusting the headband on your Skullcandy Mix Master DJ headphones, you may need to simply clean the slider tracks to remove any obstructions. This guide will show you how to that in just four few easy steps.
O que você precisa
Remove the Skullcandy Mix Master DJ Headphones from any casing or protective gear.
Quase terminado!
Conclusão
