Ir para o conteúdo principal
Cleaning the Sensors of the Cassida Counterfeit Detector
O que você precisa
  1. Cleaning the Sensors of the Cassida Counterfeit Detector, Cassida Counterfeit Detector: passo 1, imagem 1 %32
    • Remove the rubber legs.
  2. Cleaning the Sensors of the Cassida Counterfeit Detector: passo 2, imagem 1 %32
    • Using a Phillips #1 bit, remove the circled screws.
  3. Cleaning the Sensors of the Cassida Counterfeit Detector: passo 3, imagem 1 %32
    • Pry the top cover off, starting from the side with the switch, with a metal spudger.
  4. Cleaning the Sensors of the Cassida Counterfeit Detector: passo 4, imagem 1 %32
    • Pop the 4 tabs on the top of the machine up with a metal spudger and then remove the 2 side panels.
  5. Cleaning the Sensors of the Cassida Counterfeit Detector: passo 5, imagem 1 %32
    • Disconnect the wires circled and then remove the top section from the bottom section just by pulling the top section straight up and holding onto the bottom.
  6. Cleaning the Sensors of the Cassida Counterfeit Detector: passo 6, imagem 1 %32
    • All the parts disassembled.
  7. Cleaning the Sensors of the Cassida Counterfeit Detector, Cleaning the Sensors of the Cassida Counterfeit Detector: passo 7, imagem 1 %32
    • Remove the 4 screws that are circled with a Phillips #1 screwdriver.
    • Then lift up on the green motherboard.
  8. Cleaning the Sensors of the Cassida Counterfeit Detector: passo 8, imagem 1 %32
    • Once the motherboard is removed from the grey case, flip it over to expose the sensors.
  9. Cleaning the Sensors of the Cassida Counterfeit Detector: passo 9, imagem 1 %32
    • Clean the three sensors circled with isopropyl alcohol and a cue tip.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 14
Ao todo: 1,557
