Ir para o conteúdo principal
Cleaning the Fan Blades
O que você precisa
  1. Cleaning the Fan Blades, PCB (Printed Circuit Board): passo 1, imagem 1 %32
    • Use the Phillips #2 screwdriver to remove the four 6 mm screws by unscrewing counterclockwise.
  2. Cleaning the Fan Blades: passo 2, imagem 1 %32
    • Pull the front and back cover apart.
    • Be careful not to pull the front cover off completely. It holds the wires.
  3. Cleaning the Fan Blades: passo 3, imagem 1 %32
    • Remove the Phillips 6 mm screw that holds the circuit board to the outer shell of the fan.
    • Shock warning: Make sure the fan is unplugged before removing the circuit board.
  4. Cleaning the Fan Blades: passo 4, imagem 1 %32
    • Remove the top cover containing the circuit board and the wires by pulling it away from the outer shell of the fan.
  5. Cleaning the Fan Blades: passo 5, imagem 1 %32 Cleaning the Fan Blades: passo 5, imagem 2 %32
    • Remove the screws from the four corners of the circuit board.
    • Remove the circuit board from the top cover.
    • Do not touch the other side of the circuit board to avoid damaging the circuit elements.
  6. Cleaning the Fan Blades, Fan Blades: passo 6, imagem 1 %32
    • Follow steps 1-4 to remove the front, back, and top covers of the fan to reach the fan blades.
    • Use a cloth to clean off dust clogged in between the fan blades.
Conclusão
Uma outra pessoa concluiu este guia.
Vivian Fong
Membro desde: 09/26/12
97 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 15-46, Forte Fall 2012 Membro de Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 6
Últimos 30 dias: 27
Duração total: 10,711
