Ir para o conteúdo principal
Cleaning the Cutting Blade
  1. Cleaning the Cutting Blade, Cleaning the Cutting Blade: passo 1, imagem 1 %32
    • Start by placing your device on its face.
  2. Cleaning the Cutting Blade: passo 2, imagem 1 %32 Cleaning the Cutting Blade: passo 2, imagem 2 %32
    • Open the label cartridge compartment and remove any current label cartridge to reveal your label cutting blade.
  3. Cleaning the Cutting Blade: passo 3, imagem 1 %32
    • Press down on the exterior button to protrude the blade outward. Once the blade is exposed simply use a microfiber cloth or cotton swab to clean off the blade. Be sure to use rubber cleaning gloves for added safety.
    • Be careful, the blade is sharp!
Linha de Chegada
Um comentário
Group 9: Looks good. Great use of the hazard marker for the sharp blade.
Zachary Parker - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 641
