Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
You will learn how to take apart the necessary parts of the controller, how to clean the inside, and how certain parts are supposed to aligned or inserted into other parts.
O que você precisa
Remove the 9 external screws (4.8 mm Phillips head) on the back of the controller.
Remove the back panel from the controller.
Reinsert the buttons, ensuring that the rubber, cylindrical pieces protruding from the buttons are lined up with their corresponding circuits.
Follow these steps in reverse order to reassemble your device.
7 outras pessoas executaram este guia.
