Ir para o conteúdo principal
Cleaning the Controller Buttons
O que você precisa
  1. Cleaning the Controller Buttons, Cleaning the Controller Buttons: passo 1, imagem 1 %32 Cleaning the Controller Buttons, Cleaning the Controller Buttons: passo 1, imagem 2 %32
    • Remove the 9 external screws (4.8 mm Phillips head) on the back of the controller.
    • Remove the back panel from the controller.
    Pergunte ao FixBot
    Comentar
  2. Cleaning the Controller Buttons: passo 2, imagem 1 %32 Cleaning the Controller Buttons: passo 2, imagem 2 %32 Cleaning the Controller Buttons: passo 2, imagem 3 %32
    • Remove the 3 screws (4.8 mm Phillips head) from the back of the white box.
    • Remove the back panel of the joystick box.
    • There are many small plastic components loose in this box; be careful not to lose these.
    • Separate the rubber pads and plastic buttons from the controller.
    Pergunte ao FixBot
    Comentar
  3. Cleaning the Controller Buttons: passo 3, imagem 1 %32 Cleaning the Controller Buttons: passo 3, imagem 2 %32
    • Using a soft cleaning material, clean the plastic buttons.
    • Using a toothpick, clean the pole slot, shown at the right of the Q-Tip.
    Pergunte ao FixBot
    Comentar
  4. Cleaning the Controller Buttons: passo 4, imagem 1 %32 Cleaning the Controller Buttons: passo 4, imagem 2 %32
    • Using a damp, soft cleaning material, clean the rubber button pads.
    • To ensure that no electrical damage occurs, ensure that you dry the pieces completely after cleaning them.
    Pergunte ao FixBot
    Comentar
  5. Cleaning the Controller Buttons, Put it back together: passo 5, imagem 1 %32
    • Reinsert the buttons, ensuring that the rubber, cylindrical pieces protruding from the buttons are lined up with their corresponding circuits.
    Pergunte ao FixBot
    Comentar
Conclusão
Follow these steps in reverse order to reassemble your device.
7 outras pessoas executaram este guia.
Jason Gittler
Membro desde: 07/22/13
135 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 52
Ao todo: 6,562
