Ir para o conteúdo principal
Cleaning 1985-1988 Volvo 740 Throttle Body
O que você precisa
  1. Cleaning 1985-1988 Volvo 740 Throttle Body, 1985-1988 Volvo 740 Preparing Car For Work: passo 1, imagem 1 %32 Cleaning 1985-1988 Volvo 740 Throttle Body, 1985-1988 Volvo 740 Preparing Car For Work: passo 1, imagem 2 %32
    • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
  2. Cleaning 1985-1988 Volvo 740 Throttle Body, Removing Throttle Body: passo 2, imagem 1 %32
    • Locate throttle body on right side of engine, it is between the intake tube and intake manifold.
  3. Cleaning 1985-1988 Volvo 740 Throttle Body: passo 3, imagem 1 %32
    • Locate throttle linkage cable assembly.
  4. Cleaning 1985-1988 Volvo 740 Throttle Body: passo 4, imagem 1 %32 Cleaning 1985-1988 Volvo 740 Throttle Body: passo 4, imagem 2 %32
    • Twist the assembly clockwise.
  5. Cleaning 1985-1988 Volvo 740 Throttle Body: passo 5, imagem 1 %32
    • Slide both slackened cables off assembly’s guides.
  6. Cleaning 1985-1988 Volvo 740 Throttle Body: passo 6, imagem 1 %32 Cleaning 1985-1988 Volvo 740 Throttle Body: passo 6, imagem 2 %32
    • Locate the two hoses on the top of the throttle body.
    • Gently lift the hoses off.
  7. Cleaning 1985-1988 Volvo 740 Throttle Body: passo 7, imagem 1 %32
    • Use a flat head screwdriver to loosen the hose clamp attaching the intake tube to the throttle body.
  8. Cleaning 1985-1988 Volvo 740 Throttle Body: passo 8, imagem 1 %32
    • Remove the intake tube from the throttle body.
  9. Cleaning 1985-1988 Volvo 740 Throttle Body: passo 9, imagem 1 %32
    • Locate wiring clip on the underside of the throttle body.
  10. Cleaning 1985-1988 Volvo 740 Throttle Body: passo 10, imagem 1 %32 Cleaning 1985-1988 Volvo 740 Throttle Body: passo 10, imagem 2 %32
    • Press down on the locking mechanism before gently removing the wiring clip.
  11. Cleaning 1985-1988 Volvo 740 Throttle Body: passo 11, imagem 1 %32 Cleaning 1985-1988 Volvo 740 Throttle Body: passo 11, imagem 2 %32 Cleaning 1985-1988 Volvo 740 Throttle Body: passo 11, imagem 3 %32
    • Locate throttle linkage arm.
    • Open the locking clip with a flat head screwdriver.
    • Pry off the linkage arm with a flat head screwdriver.
  12. Cleaning 1985-1988 Volvo 740 Throttle Body: passo 12, imagem 1 %32 Cleaning 1985-1988 Volvo 740 Throttle Body: passo 12, imagem 2 %32 Cleaning 1985-1988 Volvo 740 Throttle Body: passo 12, imagem 3 %32
    • Locate the three 13mm nuts attaching the throttle body to the intake manifold.
    • Remove nuts with a 13mm crescent wrench.
  13. Cleaning 1985-1988 Volvo 740 Throttle Body: passo 13, imagem 1 %32
    • Lift the throttle body off of the intake manifold.
    • The manifold is now out of the engine bay and ready for cleaning or adjustment.
  14. Cleaning 1985-1988 Volvo 740 Throttle Body, Cleaning 1985-1988 Volvo 740 Throttle Body: passo 14, imagem 1 %32 Cleaning 1985-1988 Volvo 740 Throttle Body, Cleaning 1985-1988 Volvo 740 Throttle Body: passo 14, imagem 2 %32
    • Cover the electrical contacts with a shop towel to prevent throttle body cleaner from inadvertently spilling over.
  15. Cleaning 1985-1988 Volvo 740 Throttle Body: passo 15, imagem 1 %32
    • Liberally apply throttle body cleaner to the inside of throttle body and butterfly valve.
    • Use a shop towel sprayed with cleaner to wipe off thick grime if severely dirtied.
  16. Cleaning 1985-1988 Volvo 740 Throttle Body: passo 16, imagem 1 %32 Cleaning 1985-1988 Volvo 740 Throttle Body: passo 16, imagem 2 %32
    • Spray electrical cleaner on the metal contacts to blast away particles in the bracket.
    • Spray off the wiring clip that attaches to the throttle body inside the engine bay.
  17. Cleaning 1985-1988 Volvo 740 Throttle Body: passo 17, imagem 1 %32
    • Apply a small amount of dielectric grease to the metal contacts to prevent corrosion.
Conclusão
To reinstall the throttle body after cleaning follow reverse directions for prerequisite guide #2
Uma outra pessoa concluiu este guia.
Raymond
Membro desde: 10/11/10
76 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 3-28, Regan Fall 2010 Membro de Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
Membros da 4
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 35
Duração total: 8,027
