Ir para o conteúdo principal
Classique 087CQA Switches Replacement
O que você precisa
  1. Classique 087CQA Switches Replacement, Switches: passo 1, imagem 1 %32
    • Begin with the side with switches
  2. Classique 087CQA Switches Replacement: passo 2, imagem 1 %32 Classique 087CQA Switches Replacement: passo 2, imagem 2 %32
    • Remove the Phillips PH0 bit
    • Insert the bit into the screwdriver
  3. Classique 087CQA Switches Replacement: passo 3, imagem 1 %32
    • Unscrew the shell screw (1) with the screwdriver
    • 5mm Phillips flat-head screw
  4. Classique 087CQA Switches Replacement: passo 4, imagem 1 %32
    • Flip the hair dryer over to the side without switches
  5. Classique 087CQA Switches Replacement: passo 5, imagem 1 %32
    • Unscrew the shell screw (1) with the screw driver
  6. Classique 087CQA Switches Replacement: passo 6, imagem 1 %32 Classique 087CQA Switches Replacement: passo 6, imagem 2 %32
    • Remove the bit from the screwdriver and insert the Phillips PH2 bit
  7. Classique 087CQA Switches Replacement: passo 7, imagem 1 %32
    • Unscrew the remaining shell screws (5) with the screwdriver
    • 15mm Phillips round-head screws
  8. Classique 087CQA Switches Replacement: passo 8, imagem 1 %32 Classique 087CQA Switches Replacement: passo 8, imagem 2 %32
    • Gently pull the two sides apart
    • Separate each side
  9. Classique 087CQA Switches Replacement: passo 9, imagem 1 %32 Classique 087CQA Switches Replacement: passo 9, imagem 2 %32 Classique 087CQA Switches Replacement: passo 9, imagem 3 %32
    • Pull up on the switches
  10. Classique 087CQA Switches Replacement: passo 10, imagem 1 %32
    • Verify wires are connected to each switch and are in good condition
  11. Classique 087CQA Switches Replacement: passo 11, imagem 1 %32
    • Reseat the switches
  12. Classique 087CQA Switches Replacement: passo 12, imagem 1 %32 Classique 087CQA Switches Replacement: passo 12, imagem 2 %32 Classique 087CQA Switches Replacement: passo 12, imagem 3 %32
    • Check power cord for tears or kinks
Conclusão
Brandon Jestis
Membro desde: 01/31/17
1 Reputação
Autoria de 2 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 8
Ao todo: 452
