Introdução
This guide will show you how to properly replace a faulty USB or headphone input in your Cisco Meraki MC74-HW. The following seven (7) steps will guide you through the replacement. This project is meticulous so patience and care are necessary while fixing the USB/headphone jack. A pair of tweezers and a JIS #00 screwdriver are required for this project to replace the board.
O que você precisa
Extend the stand as far away as possible from the device.
Remove all four 3 mm Hex 2 screws from the stand.
Disconnect the ribbon cable on the board using a pair of reverse tweezers.
