Introdução
If you need to access the internal components of the Cisco Meraki MC74-HW or replace a broken back housing cover or stand, use this guide. This process requires a plastic spudger, bit driver, 150 mm flex extension, and H2.0 bit. The following steps present no threat or potential damage to your device.
O que você precisa
Extend the stand as far away as possible from the device.
Remove all four 3 mm Hex 2 screws from the stand.
Quase terminado!
Conclusão
