Ir para o conteúdo principal
Circuit Board Housing Removal
O que você precisa
  1. Circuit Board Housing Removal, Battery: passo 1, imagem 1 %32 Circuit Board Housing Removal, Battery: passo 1, imagem 2 %32
    • Locate the horizontal grip located on the back cover of the phone.
    • Slide the back cover down and off of the phone.
  2. Circuit Board Housing Removal: passo 2, imagem 1 %32 Circuit Board Housing Removal: passo 2, imagem 2 %32
    • Insert a plastic opening tool into the battery release point located above the battery.
    • Pull outwards in order to release the battery.
  3. Circuit Board Housing Removal, Circuit Board Housing: passo 3, imagem 1 %32 Circuit Board Housing Removal, Circuit Board Housing: passo 3, imagem 2 %32 Circuit Board Housing Removal, Circuit Board Housing: passo 3, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Locate the 5 screws holding the body of the phone together.
    • The top screw will have a plastic cover, remove it using tweezers.
    • Using a Philips head screwdriver, twist counterclockwise to remove the screws.
    • Take special care with the screw located at the top of the phone. It is smaller and more likely to be damaged or improperly attached.
  4. Circuit Board Housing Removal: passo 4, imagem 1 %32 Circuit Board Housing Removal: passo 4, imagem 2 %32
    • Lift the back cover starting at the bottom of the phone.
  5. Circuit Board Housing Removal: passo 5, imagem 1 %32 Circuit Board Housing Removal: passo 5, imagem 2 %32
    • Remove the back cover completely from the phone.
Conclusão
Jonathan Flowers
Membro desde: 10/18/13
607 Reputação
Autoria de 6 guias
Equipe
Clemson, Team 14-7, Benson Fall 2013 Membro de Clemson, Team 14-7, Benson Fall 2013
CLEM-BENSON-F13S14G7
Membros da 3
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 624
