Ir para o conteúdo principal
Cingular 8125 Speakers Replacement
O que você precisa
    • Hold the phone with the back (camera side) facing you.
    • Press on the battery cover until it slides off.
  1. Cingular 8125 Speakers Replacement: passo 2, imagem 1 %32
    • Lift up the black tab that sticks out on the battery's side until the battery is pulled out.
    • Using the iFixit Opening Tool, pull on the phone's camera cover until it pops off.
  2. Cingular 8125 Speakers Replacement: passo 3, imagem 1 %32
    • Remove the four black Torx head screws in each corner.
  3. Cingular 8125 Speakers Replacement: passo 4, imagem 1 %32
    • Pull on the back cover of the phone with the iFixit opening tool until the green motherboard is revealed.
  4. Cingular 8125 Speakers Replacement: passo 5, imagem 1 %32
    • Remove the black plastic piece from the motherboard by gently pulling it off.
    • Align the white squares on the motherboard and the speakers.
    • You'll know they are lined up correctly when the speaker's wires face the motherboard's center.
    • Press down on the white squares until they snap together.
  5. Cingular 8125 Speakers Replacement: passo 6, imagem 1 %32
    • Place the back cover of the phone over the motherboard.
    • Check to be sure the speaker's black piece is against the holes in the back cover.
    • Screw the four Torx head screws with the 64 Bit Driver Handle to connect the back cover to the motherboard.
    • Press the camera cover down on the back cover until it snaps into place.
    • Line up the copper terminal on the battery with the terminal on the phone, then press the battery back into place.
    • Make sure the black tab sticks out.
    • Slide the battery cover over the camera cover until it snaps back into place.
Conclusão
Laura Kimberly Simonds
Membro desde: 09/24/12
301 Reputação
Autoria de 2 guias
Equipe
University of Maine, Team 1-1, Diaz Fall 2012 Membro de University of Maine, Team 1-1, Diaz Fall 2012
UMAINE-DIAZ-F12S1G1
Membros da 4
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 372
