Pular para o conteúdo principal
Introdução
This guide shows how to replace the Chumby One speaker.
  1. Remove 4 self-adhesive plastic dots covering the screw holes.
    • Remove 4 self-adhesive plastic dots covering the screw holes.
  2. Remove the four 2mm screws with a Phillips screwdriver.
    • Remove the four 2mm screws with a Phillips screwdriver.
  3. Remove the back and bottom cover.
    • Remove the back and bottom cover.
  4. Disconnect the battery connector from the motherboard with a plastic opening tool.
    • Disconnect the battery connector from the motherboard with a plastic opening tool.
  5. Disconnect the microphone connector from the motherboard with a plastic opening tool.
    • Disconnect the microphone connector from the motherboard with a plastic opening tool.
  6. Remove the display ribbon cable from its socket with a plastic opening tool.
    • Remove the display ribbon cable from its socket with a plastic opening tool.
  7. Remove the volume knob from the side of the Chumby One with a plastic opening tool.
    • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
  8. Remove the four 6mm screws using a PH000 bit on the inner chassis.
    • Remove the four 6mm screws using a PH000 bit on the inner chassis.
  9. Remove the inner components from the outer shell.
    • Remove the inner components from the outer shell.
  10. Remove the speaker wire connector from the motherboard.
    • Remove the speaker wire connector from the motherboard.
  11. Remove the four 5mm screws on the speaker base with a Phillips PH00 screwdriver bit. Remove the four 5mm screws on the speaker base with a Phillips PH00 screwdriver bit.
    • Remove the four 5mm screws on the speaker base with a Phillips PH00 screwdriver bit.
  12. Remove the speaker.
    • Remove the speaker.
Conclusão
Jordan Houchins
Membro desde: 27-03-2017
401 reputação
4 Guias de autoria
Equipe
IUPUI, Team S3-G3, Baechle Spring 2017 Membro de IUPUI, Team S3-G3, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G3
4 Membros
4 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 71
