Ir para o conteúdo principal
Chumby One LCD Screen Replacement
O que você precisa
  1. Chumby One LCD Screen Replacement, Chassis: passo 1, imagem 1 %32
    • Remove 4 self-adhesive plastic dots covering the screw holes.
  2. Chumby One LCD Screen Replacement: passo 2, imagem 1 %32
    • Remove the four 2mm screws with a Phillips screwdriver.
  3. Chumby One LCD Screen Replacement: passo 3, imagem 1 %32
    • Remove the back and bottom cover.
  4. Chumby One LCD Screen Replacement: passo 4, imagem 1 %32
    • Disconnect the battery connector from the motherboard with a plastic opening tool.
  5. Chumby One LCD Screen Replacement: passo 5, imagem 1 %32
    • Disconnect the microphone connector from the motherboard with a plastic opening tool.
  6. Chumby One LCD Screen Replacement: passo 6, imagem 1 %32
    • Remove the display ribbon cable from its socket with a plastic opening tool.
  7. Chumby One LCD Screen Replacement: passo 7, imagem 1 %32
    • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
  8. Chumby One LCD Screen Replacement: passo 8, imagem 1 %32
    • Remove the four 6mm screws using a PH000 bit on the inner chassis.
  9. Chumby One LCD Screen Replacement: passo 9, imagem 1 %32
    • Remove the inner components from the outer shell.
  10. Chumby One LCD Screen Replacement, LCD Screen: passo 10, imagem 1 %32
    • Remove the four 5.5mm screws with a Phillips PH000 screwdriver bit.
  11. Chumby One LCD Screen Replacement: passo 11, imagem 1 %32
    • Remove the metal shield from the front case using a plastic opening tool.
  12. Chumby One LCD Screen Replacement: passo 12, imagem 1 %32
    • Remove the LCD screen from the outer case using a plastic opening tool.
Conclusão
Jordan Houchins
Membro desde: 03/27/17
401 Reputação
Autoria de 4 guias
Equipe
IUPUI, Team S3-G3, Baechle Spring 2017 Membro de IUPUI, Team S3-G3, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G3
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 217
