Ir para o conteúdo principal
Chromo Inc. T2 Motherboard Replacement
O que você precisa
  1. Chromo Inc. T2 Motherboard Replacement, Removing the Casing: passo 1, imagem 1 %32 Chromo Inc. T2 Motherboard Replacement, Removing the Casing: passo 1, imagem 2 %32 Chromo Inc. T2 Motherboard Replacement, Removing the Casing: passo 1, imagem 3 %32
    • Place your Plastic Opening Tool between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Motherboard Replacement, Turn it around: passo 2, imagem 1 %32
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Motherboard Replacement, Disconnecting Flex Cables: passo 3, imagem 1 %32 Chromo Inc. T2 Motherboard Replacement, Disconnecting Flex Cables: passo 3, imagem 2 %32
    • Peel back the tape holding the big flex cable in place.
    • Using your plastic opening tool, gently push back the gray connector to free the flex cables and then pull them out.
  4. Chromo Inc. T2 Motherboard Replacement, Disconnecting the Camera: passo 4, imagem 1 %32 Chromo Inc. T2 Motherboard Replacement, Disconnecting the Camera: passo 4, imagem 2 %32
    • Using the small plastic opening tool, gently push the gray connector back to unlock the flex cable.
    • Using a pair of tweezers, gently grasp the flex cable and disconnect it from the connector.
  5. Chromo Inc. T2 Motherboard Replacement: passo 5, imagem 1 %32 Chromo Inc. T2 Motherboard Replacement: passo 5, imagem 2 %32
    • Using a Phillips #00 Precision Screwdriver, remove the three 3mm screws holding the motherboard.
  6. Chromo Inc. T2 Motherboard Replacement: passo 6, imagem 1 %32 Chromo Inc. T2 Motherboard Replacement: passo 6, imagem 2 %32 Chromo Inc. T2 Motherboard Replacement: passo 6, imagem 3 %32
    • Using your soldering iron, desolder the six wires on the side of the logic board.
    • Note: Remember where these wires go as re-connecting them incorrectly can lead to damaging the device!
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
  7. Chromo Inc. T2 Motherboard Replacement: passo 7, imagem 1 %32 Chromo Inc. T2 Motherboard Replacement: passo 7, imagem 2 %32
    • Using your soldering Iron, desolder the grounding cable on the motherboard.
  8. Chromo Inc. T2 Motherboard Replacement: passo 8, imagem 1 %32
    • Your motherboard is now ready for replacement!
Conclusão
Ismael DeLuna
Membro desde: 01/21/15
625 Reputação
5 Guias de autoria
Equipe
USF Tampa, Team 15-1, Watkins Winter 2015 Membro de USF Tampa, Team 15-1, Watkins Winter 2015
USFT-WATKINS-W15S15G1
4 Membros
6 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 597
