Ir para o conteúdo principal
Chromo Inc. T2 Internal Speaker Replacement
O que você precisa
  1. Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: passo 1, imagem 1 %32 Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: passo 1, imagem 2 %32 Chromo Inc. T2 Internal Speaker Replacement, Removing the Casing: passo 1, imagem 3 %32
    • Using your Plastic Opening Tool, place it in between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Internal Speaker Replacement, Turn it around: passo 2, imagem 1 %32
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: passo 3, imagem 1 %32 Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: passo 3, imagem 2 %32 Chromo Inc. T2 Internal Speaker Replacement, Removing the Tape: passo 3, imagem 3 %32
    • Remove two strips of tape: One holding down the wires and the other holding down the internal speaker.
  4. Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: passo 4, imagem 1 %32 Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: passo 4, imagem 2 %32 Chromo Inc. T2 Internal Speaker Replacement, Desoldering the Wires and Removing the Speaker: passo 4, imagem 3 %32
    • Using a Soldering Iron, desolder both speaker wires. Once both wires are desoldered, your Internal Speaker is now ready for replacement!
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
Conclusão
Ismael DeLuna
Membro desde: 01/21/15
637 Reputação
5 Guias de autoria
Equipe
USF Tampa, Team 15-1, Watkins Winter 2015 Membro de USF Tampa, Team 15-1, Watkins Winter 2015
USFT-WATKINS-W15S15G1
4 Membros
6 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 189
