O que você precisa
Using your Plastic Opening Tool, place it in between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
After separating the case and screen, turn your screen face down so you can see the internal parts!
Remove two strips of tape: One holding down the wires and the other holding down the internal speaker.
Using a Soldering Iron, desolder both speaker wires. Once both wires are desoldered, your Internal Speaker is now ready for replacement!
