Ir para o conteúdo principal
Chromo Inc. T2 Front Facing Camera Replacement
O que você precisa
  1. Chromo Inc. T2 Front Facing Camera Replacement, Removing the Casing: passo 1, imagem 1 %32 Chromo Inc. T2 Front Facing Camera Replacement, Removing the Casing: passo 1, imagem 2 %32 Chromo Inc. T2 Front Facing Camera Replacement, Removing the Casing: passo 1, imagem 3 %32
    • Place your Plastic Opening Tool between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Front Facing Camera Replacement, Turn it around: passo 2, imagem 1 %32
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Front Facing Camera Replacement, Getting to the camera: passo 3, imagem 1 %32
    • Remove the tape that holds the camera in place.
  4. Chromo Inc. T2 Front Facing Camera Replacement, Free up the flex cable: passo 4, imagem 1 %32
    • Using the small plastic opening tool, gently push the gray connector back to unlock the flex cable.
  5. Chromo Inc. T2 Front Facing Camera Replacement, Removing the Flex Cable and Camera: passo 5, imagem 1 %32 Chromo Inc. T2 Front Facing Camera Replacement, Removing the Flex Cable and Camera: passo 5, imagem 2 %32
    • Using a pair of tweezers, gently grasp the flex cable and pull it out while using your other hand to keep the camera in place. Once removed, your camera is now free and ready for replacement!
Conclusão
Ismael DeLuna
Membro desde: 01/21/15
637 Reputação
5 Guias de autoria
Equipe
USF Tampa, Team 15-1, Watkins Winter 2015 Membro de USF Tampa, Team 15-1, Watkins Winter 2015
USFT-WATKINS-W15S15G1
4 Membros
6 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 205
