Introdução
Power buttons notoriously end up inside of devices if too much force is applied. This guide aims to replace the power button into it's desired location.
Ferramentas
Peças
Não são necessárias peças.
Place the Google Chromecast face down (with text not showing) on a flat surface.
Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
Press the plastic button from the outside of the port, pushing it inward if it is stuck.
