Ir para o conteúdo principal
Chromebook x360 14-da0011dx Wireless Card Replacement
O que você precisa
  1. Chromebook x360 14-da0011dx Wireless Card Replacement, Lower Case: passo 1, imagem 1 %32
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. Chromebook x360 14-da0011dx Wireless Card Replacement: passo 2, imagem 1 %32 Chromebook x360 14-da0011dx Wireless Card Replacement: passo 2, imagem 2 %32
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. Chromebook x360 14-da0011dx Wireless Card Replacement: passo 3, imagem 1 %32 Chromebook x360 14-da0011dx Wireless Card Replacement: passo 3, imagem 2 %32 Chromebook x360 14-da0011dx Wireless Card Replacement: passo 3, imagem 3 %32
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
  4. Chromebook x360 14-da0011dx Wireless Card Replacement, Wireless card: passo 4, imagem 1 %32
    • Remove the plastic protector from the top of the wires plugged into the wireless card.
  5. Chromebook x360 14-da0011dx Wireless Card Replacement: passo 5, imagem 1 %32
    • Remove the single 3 mm screw holding down the wireless card with the Phillips #1 screwdriver.
  6. Chromebook x360 14-da0011dx Wireless Card Replacement: passo 6, imagem 1 %32 Chromebook x360 14-da0011dx Wireless Card Replacement: passo 6, imagem 2 %32
    • Disconnect the antenna cables leading into the wireless card.
    • Slide the wireless card out of its port and lift it out of the device.
    • The cables are numbered with their corresponding port. Be careful not to damage the connections when reassembling during this step.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 22
Duração total: 149
