Introdução
This guide offers instructions for replacing the motherboard on your Chromebook x360 14-da0011dx. Removal of the motherboard requires removing both the battery and cooling fan.
Note: When re-installing a new motherboard, the heat pipes and thermal paste may need to be installed on the new motherboard.
O que você precisa
Flip the device over with the hinge facing away from you.
On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
Uma outra pessoa concluiu este guia.
