O que você precisa
There are two metal bars across the passenger and driver side to lift the car with a jack.
Its a 16 mm nut
After all oil has drain reinsert the 16mm nut back and clean around it.
The filter can be seen from the tire.
Apply the new filter with a dab of oil around the top for lubrication.
Quase terminado!
Congratulation you have successfully done your first or another oil change.
Conclusão
