Ir para o conteúdo principal
Chevy 305 Engine Oil Pump Replacement
O que você precisa
  1. Chevy 305 Engine Oil Pump Replacement, Oil pump: passo 1, imagem 1 %32 Chevy 305 Engine Oil Pump Replacement, Oil pump: passo 1, imagem 2 %32
    • Remove the 18 bolts holding the oil pan in place using the 3⁄8 and 1⁄2 sockets, 6 inch extension and 3⁄8 ratchet.
    • Fourteen 3/8 bolts around the perimeter and four 1/2 bolts on each corner
    • Lift the oil pan up and forward so the oil pump pick up will clear the baffle.
    • Do not remove the oil pan gasket yet.
  2. Chevy 305 Engine Oil Pump Replacement: passo 2, imagem 1 %32 Chevy 305 Engine Oil Pump Replacement: passo 2, imagem 2 %32
    • Remove the single 9/16 bolt holding the oil pump in place.
    • Using a rubber mallet to break loose, gently tap on the side of the base of the pump indicated by the arrow. DO NOT HIT THE TOP OF THE PICK UP TUBE AND SCREEN. This can potentially damage the pick up tube or screen.
  3. Chevy 305 Engine Oil Pump Replacement: passo 3, imagem 1 %32
    • Pull straight up from the base of the oil pump to remove.
    • Replace with a new oil pump.
Conclusão
To reassemble your device, follow these instructions in reverse order. Torque oil pump bolt to 60-70ft.-lbs. Torque oil pan bolts to 12ft.-lbs.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 15
Últimos 30 dias: 46
Ao todo: 3,710
