Ir para o conteúdo principal
Chevy 305 Engine Main Bearings Replacement
O que você precisa
  1. Chevy 305 Engine Main Bearings Replacement, Main Bearings: passo 1, imagem 1 %32 Chevy 305 Engine Main Bearings Replacement, Main Bearings: passo 1, imagem 2 %32
    • Remove the 18 bolts holding the oil pan in place (fourteen ⅜” bolts & four ½” bolts on each corner) and remove oil pan using the 3⁄8 and 1⁄2 sockets, 6 inch extension and 3⁄8 ratchet.
    • Do not remove the oil pan gasket yet.
    Pergunte ao FixBot
    Comentar
  2. Chevy 305 Engine Main Bearings Replacement: passo 2, imagem 1 %32
    • Remove the 5 main bearing caps.
    • Three caps with four ⅝ bolts and two caps with two ⅝ bolts at the front and rear of crankshaft.
    • Gently tap the side of the cap with a rubber mallet if needed to break free.
    • DO NOT SWAP THE LOCATIONS OR DIRECTIONS OF THE CAPS.
    Pergunte ao FixBot
    Comentar
  3. Chevy 305 Engine Main Bearings Replacement: passo 3, imagem 1 %32
    • Remove and replace main bearings.
    • Liberally apply assembly lubricant/oil to the new bearing surfaces and crankshaft journal.
    • Gently tap the cap against the engine block or use a thin flathead to remove.
    Pergunte ao FixBot
    Comentar
  4. Chevy 305 Engine Main Bearings Replacement: passo 4, imagem 1 %32
    • Put the main bearing caps back.
    • Three caps with four ⅝ bolts and two caps with two ⅝ bolts at the front and rear of crankshaft and torque to specs. (65 ft.-lbs.)
    • Do not swap the locations or directions of the caps during reinstallation. (reverse of removal)
    Pergunte ao FixBot
    Comentar
  5. Chevy 305 Engine Main Bearings Replacement: passo 5, imagem 1 %32 Chevy 305 Engine Main Bearings Replacement: passo 5, imagem 2 %32
    • Replace the oil pan gasket.
    • Use a razor blade, flathead screwdriver or putty knife to clean up the old gasket and wipe down where the old gasket was with brake cleaner and paper towels before placing a new gasket.
    • Be careful not to drop any gasket debris into the engine.
    Pergunte ao FixBot
    Comentar
  6. Chevy 305 Engine Main Bearings Replacement: passo 6, imagem 1 %32
    • Put the oil pan back into place.
    • Fourteen ⅜” bolts & four ½” bolts on each corner) and torque bolts to specs. (12 ft.-lbs.) (reverse of removal)
    Pergunte ao FixBot
    Comentar
Linha de Chegada
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 18
Últimos 30 dias: 71
Ao todo: 4,122
