Ir para o conteúdo principal
Chefman RJ-38-V2-35 Fryer Basket Replacement
O que você precisa
  1. Chefman RJ-38-V2-35 Fryer Basket Replacement, Fryer Basket: passo 1, imagem 1 %32
    • Make sure the air fryer is unplugged and the basket is cool enough to handle.
    • Remove the basket from the air fryer.
  2. Chefman RJ-38-V2-35 Fryer Basket Replacement: passo 2, imagem 1 %32
    • Place the fryer basket on a flat surface.
    • Using the Phillips #1 screwdriver, remove four 5mm screws on the inside of the fryer basket (left two screws shown).
  3. Chefman RJ-38-V2-35 Fryer Basket Replacement: passo 3, imagem 1 %32
    • Separate the handle from the basket.
Conclusão
Uma outra pessoa concluiu este guia.
Benn Rutledge
Membro desde: 10/17/18
127 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team S1-G4, Rose Fall 2018 Membro de UW Tacoma, Team S1-G4, Rose Fall 2018
UWT-ROSE-F18S1G4
Membros da 4
Autoria de 3 guias
4 comentários
I need the plate inside the basket. The coating is coming off, Is it safe to use?
Eileen Morrison - Responder
Where can I buy only the basket or just the plate? I need replacement but don’t seem to find the parts…
Eszter Stranszky - Responder
I need the plate inside the basket. Coating is coming off.
Sandy Mentzer - Responder
Where can I buy replacement rubber feet for the fryer basket plate? Mine came off and went down the disposal!! Are they required for proper heating and frying??
Betty Johnson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 53
Duração total: 3,544
