Ir para o conteúdo principal
Chef's Choice M115 Linkage Pins Replacement
O que você precisa
  1. Chef's Choice M115 Linkage Pins Replacement, Case: passo 1, imagem 1 %32 Chef's Choice M115 Linkage Pins Replacement, Case: passo 1, imagem 2 %32
    • Remove the two rubber feet on the motor side of the device.
    • Remove the five Phillips screws from the bottom of the case.
    • These screws are recessed deep in the device, so a long, thin screwdriver is required.
  2. Chef's Choice M115 Linkage Pins Replacement: passo 2, imagem 1 %32
    • Remove the two hex-cap screws on the bottom using a pair of pliers.
  3. Chef's Choice M115 Linkage Pins Replacement: passo 3, imagem 1 %32
    • Carefully flip the device right-side-up while grasping the top and bottom pieces.
    • The white cover should lift off with no resistance. If it does not, ensure all screws were removed in previous step.
  4. Chef's Choice M115 Linkage Pins Replacement: passo 4, imagem 1 %32
    • Remove the sharpener guard by gently pulling up on it.
    • If the sharpener guard does not come off easily, ensure all screws were removed in step 1.
  5. Chef's Choice M115 Linkage Pins Replacement, Grinding Disc Linkage Pins: passo 5, imagem 1 %32
    • Remove the motor and shaft assembly from the bottom of the case housing.
  6. Chef's Choice M115 Linkage Pins Replacement: passo 6, imagem 1 %32 Chef's Choice M115 Linkage Pins Replacement: passo 6, imagem 2 %32
    • Use a screwdriver to push the pin out of the rod.
    • Use pliers to pull the pin the rest of the way out.
Conclusão
Uma outra pessoa concluiu este guia.
James Herin
Membro desde: 10/27/15
128 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 3-3, Harley Fall 2015 Membro de IUPUI, Team 3-3, Harley Fall 2015
IUPUI-HARLEY-F15S3G3
Membros da 5
Autoria de 12 guias
Um comentário
Where would you obtain new linkage pins. Can I use a similar gauged wire? What, and where can I find a suitable replacement?
Josh Brown - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 22
Duração total: 1,900
