Ir para o conteúdo principal
Change Battery Remote Control Ford Focus MK3 Battery CR2032 Replacement
O que você precisa
  1. Change Battery Remote Control Ford Focus MK3  Battery CR2032 Replacement, Battery CR2032: passo 1, imagem 1 %32
    • To open the remote control you need a circlip caliper (in german: Seegerringzange ;).
    • The forks of the tool are moving away from each other, when you pull the handles together
  2. Change Battery Remote Control Ford Focus MK3  Battery CR2032 Replacement: passo 2, imagem 1 %32
    • Place the tool in the indentation.
    • The forks moving direction has to be perpendicular to the gap of the case .
    • prie one side open then do the same on the other side
  3. Change Battery Remote Control Ford Focus MK3  Battery CR2032 Replacement: passo 3, imagem 1 %32
    • Remove the spent battery with the nonconductive spudger tool
  4. Change Battery Remote Control Ford Focus MK3  Battery CR2032 Replacement: passo 4, imagem 1 %32
    • Place the new battery in the mounting
    • Check Polarity! Negative pole is facing you.
    • Carefully put the case together
    • Cover old battery with duct tape and take care of the disposal.
    • Be happy an drive safely, because you're done!
Conclusão
Uma outra pessoa concluiu este guia.
Michael
Membro desde: 10/03/17
178 Reputação
Autoria de 1 guia
Um comentário
You can also do it easily with only one flathead screwdriver, as shown in this video: https://youtu.be/95isoDxrPGg?si=rHpZW8_i...
Alex - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 41
Duração total: 1,014
