Ir para o conteúdo principal
Chain Adjustment
  1. Chain Adjustment, Chain Adjustment: passo 1, imagem 1 %32 Chain Adjustment, Chain Adjustment: passo 1, imagem 2 %32 Chain Adjustment, Chain Adjustment: passo 1, imagem 3 %32
    • Locate the two nuts and screws to adjust the chain saw.
    • YOU MAY NEED TO PULL THE BLACK INTER CASING THAT THE CHAIN GO AROUND TO TIGHT
  2. Chain Adjustment: passo 2, imagem 1 %32 Chain Adjustment: passo 2, imagem 2 %32 Chain Adjustment: passo 2, imagem 3 %32
    • USE nut driver 7/16 to loosen the nuts and realignment chain around the black casing.
    • Tight the chain saw chain that it tight enough that it move around the black inter case.
    • YOU must have to readjust move than once.
    • Must have to pull the black casing forward . Readjust the nuts agaian.
Conclusão
kempc8
Membro desde: 11/22/13
905 Reputação
Autoria de 7 guias
Equipe
K and K Fixit Membro de K and K Fixit
Business
1 Membro
Autoria de 11 guias
Um comentário
Hi kempc8,
Recently i came up with a post Ultimate Pole saw guide 2017.
I have also listed Top brands with respect to Pole saw.
I probably missed out your brand
Kindly give a look here link to bestpolesaw.com
Please suggest me whether i can add your brand or any of the products associated with our niche .
Thanks
rmanojkumar.007 - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 31
Ao todo: 2,303
