Introdução
This is the guide for replacing the focus knob on the Celestron Nature DX 8x25 Binoculars. If the focus knob is not adjusting, it might have to be replaced.
O que você precisa
Using a plastic opening tool, nylon spudger or metal spudger, pry into seam of the skin cover at the center of the device. Lightly lift the tool which should cause the skin cover to rise.
Remove the top cover of the focus knob as shown. Simply twisting and pulling the cover will slide it off.
Um comentário
Hello.
I have the same model with a little bit to hard working focus knob.
Is it possible to adjust it in order to make it working smoothly?
Tkanks.
