Ir para o conteúdo principal
Celestron HomeCast Lite 47020 Main Unit Battery Replacement
  1. Celestron HomeCast Lite 47020 Main Unit Battery Replacement, Main Unit Battery: passo 1, imagem 1 %32
    • Left: Remote sensor; Right: Main unit
    • In this guide, we will replace new batteries for the main unit.
    • Before beginning, gather the following tools and replacement parts: Replacement battery (compatible with Celestron HomeCast Lite 47020) Small Phillips-head screwdriver Plastic opening tool (optional but helpful) Clean cloth or workspace
  2. Celestron HomeCast Lite 47020 Main Unit Battery Replacement: passo 3, imagem 1 %32 Celestron HomeCast Lite 47020 Main Unit Battery Replacement: passo 3, imagem 2 %32 Celestron HomeCast Lite 47020 Main Unit Battery Replacement: passo 3, imagem 3 %32
    • Power off the Celestron HomeCast Lite 47020 and unplug it from any power source. This will help avoid electrical hazards and prevent accidental activation during the repair.
  3. Celestron HomeCast Lite 47020 Main Unit Battery Replacement: passo 4, imagem 1 %32
    • Locate the battery compartment on the back of the unit. If secured with screws, use the Phillips-head screwdriver to remove them. If secured with latches, gently use the plastic opening tool to release them.
    • If the compartment has latches, use the plastic opening tool to carefully release them. Avoid using excessive force to prevent damage to the compartment or cover.
    • Once the compartment is open, gently lift the old battery out. If it's secured with clips or adhesive, use the plastic opening tool to carefully release it without damaging surrounding components.
    • If the old battery is swollen, damaged, or leaking, wear gloves to handle it safely. Dispose of it according to local regulations.
    • Align the new battery with the compartment, ensuring the positive and negative terminals match. Press it gently into place without using excessive force.
    • Once the new battery is in place, replace the compartment cover. If screws were used, tighten them carefully with the Phillips-head screwdriver, ensuring not to overtighten.
    • Power on the device and ensure it functions correctly. If it doesn’t turn on or isn’t performing as expected, check the battery connections or consult the troubleshooting guide for assistance.
Conclusão
xin zhao
Membro desde: 02/04/19
243 Reputação
Autoria de 2 guias
Equipe
UC Davis, Team S18-G7, Lore Winter 2019 Membro de UC Davis, Team S18-G7, Lore Winter 2019
UCD-LORE-W19S18G7
4 Membros
Autoria de 3 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 28
Ao todo: 134
