Ir para o conteúdo principal
Ceiva LF2003 Power Supply Board Replacement
O que você precisa
  1. Ceiva LF2003 Power Supply Board Replacement, Exterior Frame and Matting: passo 1, imagem 1 %32
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Ceiva LF2003 Power Supply Board Replacement: passo 2, imagem 1 %32
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Ceiva LF2003 Power Supply Board Replacement: passo 3, imagem 1 %32
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Ceiva LF2003 Power Supply Board Replacement: passo 4, imagem 1 %32
    • Remove the frame and matte from the device.
  5. Ceiva LF2003 Power Supply Board Replacement, Internal Plastic Screen Frame: passo 5, imagem 1 %32
    • Remove the four 7mm Torx T6 screws.
  6. Ceiva LF2003 Power Supply Board Replacement: passo 6, imagem 1 %32 Ceiva LF2003 Power Supply Board Replacement: passo 6, imagem 2 %32
    • Using the plastic opening tool or your fingers, lift up the frame from any edge.
    • Remove the frame from the device.
  7. Ceiva LF2003 Power Supply Board Replacement, Display: passo 7, imagem 1 %32 Ceiva LF2003 Power Supply Board Replacement, Display: passo 7, imagem 2 %32 Ceiva LF2003 Power Supply Board Replacement, Display: passo 7, imagem 3 %32
    • Unplug the cable connecting the display to the power supply using the flat end of the spudger to pry the connector away from the circuit board.
    • Alternate applying pressure to the left and right side of the connector to ensure that it does not break.
  8. Ceiva LF2003 Power Supply Board Replacement: passo 8, imagem 1 %32
  9. Ceiva LF2003 Power Supply Board Replacement: passo 9, imagem 1 %32 Ceiva LF2003 Power Supply Board Replacement: passo 9, imagem 2 %32
    • Lift up the display from the left edge and flip display over.
    • Do not lift the display too quickly, as the display is still connected to the main circuit board on the right.
  10. Ceiva LF2003 Power Supply Board Replacement: passo 10, imagem 1 %32 Ceiva LF2003 Power Supply Board Replacement: passo 10, imagem 2 %32 Ceiva LF2003 Power Supply Board Replacement: passo 10, imagem 3 %32
    • Use the spudger to disconnect the ribbon cable from the display by the black pins away from the connector. There is a pin on either side of the connector.
    • Once both pins are released, the ribbon cable should slide easily out.
    • It may be easier if someone else holds the display so the cable does not get ripped out.
  11. Ceiva LF2003 Power Supply Board Replacement: passo 11, imagem 1 %32
    • Remove the display assembly from the device.
  12. Ceiva LF2003 Power Supply Board Replacement, Power Supply Board: passo 12, imagem 1 %32
  13. Ceiva LF2003 Power Supply Board Replacement: passo 13, imagem 1 %32 Ceiva LF2003 Power Supply Board Replacement: passo 13, imagem 2 %32
    • Desolder the 3 wires attached to the board.
    • Remove the power supply board from the device.
    • The wires shown were not actually desoldered, but the board will now be separated from the rest of the device.
Conclusão
Uma outra pessoa concluiu este guia.
Casey Glasgow
Membro desde: 01/26/14
510 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 9-25, Maness Winter 2014 Membro de Cal Poly, Team 9-25, Maness Winter 2014
CPSU-MANESS-W14S9G25
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 155
