Ir para o conteúdo principal
Ceiva LF2003 Exterior Frame and Matting Replacement
  1. Ceiva LF2003 Exterior Frame and Matting Replacement, Exterior Frame and Matting: passo 1, imagem 1 %32
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Ceiva LF2003 Exterior Frame and Matting Replacement: passo 2, imagem 1 %32
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Ceiva LF2003 Exterior Frame and Matting Replacement: passo 3, imagem 1 %32
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Ceiva LF2003 Exterior Frame and Matting Replacement: passo 4, imagem 1 %32
    • Remove the frame and matte from the device.
Conclusão
Casey Glasgow
Membro desde: 01/26/14
510 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 9-25, Maness Winter 2014 Membro de Cal Poly, Team 9-25, Maness Winter 2014
CPSU-MANESS-W14S9G25
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 102
