Ir para o conteúdo principal
Ceiva LF2003 Display Replacement
O que você precisa
  1. Ceiva LF2003 Display Replacement, Exterior Frame and Matting: passo 1, imagem 1 %32
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Ceiva LF2003 Display Replacement: passo 2, imagem 1 %32
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Ceiva LF2003 Display Replacement: passo 3, imagem 1 %32
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Ceiva LF2003 Display Replacement: passo 4, imagem 1 %32
    • Remove the frame and matte from the device.
  5. Ceiva LF2003 Display Replacement, Internal Plastic Screen Frame: passo 5, imagem 1 %32
    • Remove the four 7mm Torx T6 screws.
  6. Ceiva LF2003 Display Replacement: passo 6, imagem 1 %32 Ceiva LF2003 Display Replacement: passo 6, imagem 2 %32
    • Using the plastic opening tool or your fingers, lift up the frame from any edge.
    • Remove the frame from the device.
  7. Ceiva LF2003 Display Replacement, Display: passo 7, imagem 1 %32 Ceiva LF2003 Display Replacement, Display: passo 7, imagem 2 %32 Ceiva LF2003 Display Replacement, Display: passo 7, imagem 3 %32
    • Unplug the cable connecting the display to the power supply using the flat end of the spudger to pry the connector away from the circuit board.
    • Alternate applying pressure to the left and right side of the connector to ensure that it does not break.
  8. Ceiva LF2003 Display Replacement: passo 8, imagem 1 %32
  9. Ceiva LF2003 Display Replacement: passo 9, imagem 1 %32 Ceiva LF2003 Display Replacement: passo 9, imagem 2 %32
    • Lift up the display from the left edge and flip display over.
    • Do not lift the display too quickly, as the display is still connected to the main circuit board on the right.
  10. Ceiva LF2003 Display Replacement: passo 10, imagem 1 %32 Ceiva LF2003 Display Replacement: passo 10, imagem 2 %32 Ceiva LF2003 Display Replacement: passo 10, imagem 3 %32
    • Use the spudger to disconnect the ribbon cable from the display by the black pins away from the connector. There is a pin on either side of the connector.
    • Once both pins are released, the ribbon cable should slide easily out.
    • It may be easier if someone else holds the display so the cable does not get ripped out.
  11. Ceiva LF2003 Display Replacement: passo 11, imagem 1 %32
    • Remove the display assembly from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Casey Glasgow
Membro desde: 01/26/14
510 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 9-25, Maness Winter 2014 Membro de Cal Poly, Team 9-25, Maness Winter 2014
CPSU-MANESS-W14S9G25
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 135
