Ir para o conteúdo principal
Ceiling Fan Pull Chain Switch Replacement
O que você precisa
  1. Ceiling Fan Pull Chain Switch Replacement, Pull Chain Switch: passo 1, imagem 1 %32 Ceiling Fan Pull Chain Switch Replacement, Pull Chain Switch: passo 1, imagem 2 %32
    • Caution: Turn off the power from the circuit breaker and turn off any light switches that provide power to the ceiling fan.
    • Remove the white cover by unscrewing the nut on the bottom from where the chain is hanging.
  2. Ceiling Fan Pull Chain Switch Replacement: passo 2, imagem 1 %32 Ceiling Fan Pull Chain Switch Replacement: passo 2, imagem 2 %32 Ceiling Fan Pull Chain Switch Replacement: passo 2, imagem 3 %32
    • Caution: Let the bulbs cool off before you remove them.
    • Remove the bulbs from their sockets.
  3. Ceiling Fan Pull Chain Switch Replacement: passo 3, imagem 1 %32 Ceiling Fan Pull Chain Switch Replacement: passo 3, imagem 2 %32
    • Remove the screws around the base.
    • Remove the fan housing.
  4. Ceiling Fan Pull Chain Switch Replacement: passo 4, imagem 1 %32
    • Pull the switch out of the fan housing, leaving the wires attached.
  5. Ceiling Fan Pull Chain Switch Replacement: passo 5, imagem 1 %32 Ceiling Fan Pull Chain Switch Replacement: passo 5, imagem 2 %32 Ceiling Fan Pull Chain Switch Replacement: passo 5, imagem 3 %32
    • Cut the colored wires from the switch using a pair of wire cutters.
    • On some switch models, the wires can be detached by pulling.
  6. Ceiling Fan Pull Chain Switch Replacement: passo 6, imagem 1 %32 Ceiling Fan Pull Chain Switch Replacement: passo 6, imagem 2 %32 Ceiling Fan Pull Chain Switch Replacement: passo 6, imagem 3 %32
    • Note the wire colors and the terminal they attach to on the old switch.
    • 1 - Red
    • 2 - Purple
    • 3 - Yellow
    • L - Black
  7. Ceiling Fan Pull Chain Switch Replacement: passo 7, imagem 1 %32
    • Attach the colored wires to the new switch's respective terminals.
  8. Ceiling Fan Pull Chain Switch Replacement: passo 8, imagem 1 %32 Ceiling Fan Pull Chain Switch Replacement: passo 8, imagem 2 %32
    • Put back the switch in the hole in the fan housing from the inside.
    • Tighten up the screws on the outside.
  9. Ceiling Fan Pull Chain Switch Replacement: passo 9, imagem 1 %32 Ceiling Fan Pull Chain Switch Replacement: passo 9, imagem 2 %32 Ceiling Fan Pull Chain Switch Replacement: passo 9, imagem 3 %32
    • Put back the white cover and then tighten up the nut at the bottom of the cover from where the chain is hanging.
  10. Ceiling Fan Pull Chain Switch Replacement: passo 10, imagem 1 %32 Ceiling Fan Pull Chain Switch Replacement: passo 10, imagem 2 %32
    • Turn the power back on and test the switch to find if it is working or not.
Linha de Chegada
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 82
Últimos 30 dias: 399
Duração total: 11,082
