Ir para o conteúdo principal
Caterpillar B15 Battery Replacement
O que você precisa
  1. Caterpillar B15 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
  2. Caterpillar B15 Battery Replacement: passo 2, imagem 1 %32 Caterpillar B15 Battery Replacement: passo 2, imagem 2 %32
    • Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
  3. Caterpillar B15 Battery Replacement: passo 3, imagem 1 %32 Caterpillar B15 Battery Replacement: passo 3, imagem 2 %32
    • Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone. The new battery can be inserted where the old one was. The phone can be reassembled by following these steps in reverse.
Conclusão
5 outras pessoas executaram este guia.
Geoffrey Mosdell
Membro desde: 10/06/14
1.119 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 4-7, Brown Fall 2014 Membro de USF Tampa, Team 4-7, Brown Fall 2014
USFT-BROWN-F14S4G7
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 3,799
