Peças
  1. This is the calculator in question.
    • This is the calculator in question.
      • Features a black and white dot matrix screen.
  2. Turn the calculator over. Locate the six screws on the rear of the device.
    • Turn the calculator over.
    • Locate the six screws on the rear of the device.
      • These are Philips #00 screws.
    • Keep the screws you remove in a safe place so they don't get lost.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Once the screws are removed, carefully lift the back panel off, lifting the top end first. Place the panel to one side.
    • Once the screws are removed, carefully lift the back panel off, lifting the top end first.
    • Place the panel to one side.
    • You can now see the battery.
  5. Remove the battery
    • Remove the battery
    • Lift it up from the right hand side to avoid damaging the spring.
    • You may find this easier to do by prying it out with the screwdriver.
  6. Now you can insert the new battery Ensure you place it in spring-first.
    • Now you can insert the new battery
      • Ensure you place it in spring-first.
    • Congratulations! You have replaced the battery.
    • When reassembling, take care not to trap the red or black wires in the screws as this would sever them, making the calculator unusable.
    • Once reassembled, the calculator will be turned on. Turn it off to save battery by pressing Shift --> AC.
Conclusão
To reassemble your device, follow these instructions in reverse order, noting the two reassembly instructions in the last step.
23 outras pessoas concluíram este guia.
Sam
869 reputação
Autoria de 1 guia
For some reason the two top screws made the calculator unstable, but removing them made it stable. Only occurred after removing the battery
Mida Galbraith - Responder
what battery size is it? R03?
Humerdom - Responder
Visualizar Estatísticas:
Últimas 24 horas: 23
Últimos 7 dias: 107
Últimos 30 dias: 566
Todo: 34,016
