Ir para o conteúdo principal
Casio MarineGear wristwatch battery Replacement
O que você precisa
  1. Casio MarineGear wristwatch battery Replacement, Opening the back: passo 1, imagem 1 %32 Casio MarineGear wristwatch battery Replacement, Opening the back: passo 1, imagem 2 %32
    • Use a Phillips #00 to remove the 4 screws holding the back.
  2. Casio MarineGear wristwatch battery Replacement, Remove plastic ring and movement: passo 2, imagem 1 %32 Casio MarineGear wristwatch battery Replacement, Remove plastic ring and movement: passo 2, imagem 2 %32 Casio MarineGear wristwatch battery Replacement, Remove plastic ring and movement: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use the tweezers to remove the plastic ring that aligns the movement.
    • In this case the watch didn't have a battery installed, but to get the battery out you have to use the tweezers and unhook the latch holding the battery in place.
    • The correct battery for this watch is CR2025 3V button cell.
  3. Casio MarineGear wristwatch battery Replacement, Install new battery: passo 3, imagem 1 %32 Casio MarineGear wristwatch battery Replacement, Install new battery: passo 3, imagem 2 %32
    • Insert the new battery into it's place.
    • Latch the battery hook back into it's place, securing the battery.
    • Turn the movement over to verify the watch is now working.
    • You may have to touch the AC (negative) side of battery, to the metal grounding plate. (It's stated on the white label and marks are very clear).
  4. Casio MarineGear wristwatch battery Replacement, Reassemble the watch: passo 4, imagem 1 %32 Casio MarineGear wristwatch battery Replacement, Reassemble the watch: passo 4, imagem 2 %32 Casio MarineGear wristwatch battery Replacement, Reassemble the watch: passo 4, imagem 3 %32
    • Make sure the rubber gasket is placed correctly in it's groove, as it is there for water resistance.
    • Place the back cover on and fasten the 4 Phillips #00 screws securing the back plate.
    • Set the time and date, and your watch is now in working order again.
Conclusão
Reassembly is detailed in the guide
Geir Ove Andersen
Membro desde: 06/06/22
8.046 Reputação
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 28
Ao todo: 1,626
