Ir para o conteúdo principal
Casio MTD-120 Battery Replacement
O que você precisa
  1. Casio MTD-120 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Place the watch upside down.
  2. Casio MTD-120 Battery Replacement: passo 2, imagem 1 %32 Casio MTD-120 Battery Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the back cover of the watch with tweezers.
    • This should reveal a plastic cover once the back is removed.
  3. Casio MTD-120 Battery Replacement: passo 3, imagem 1 %32 Casio MTD-120 Battery Replacement: passo 3, imagem 2 %32
    • Remove the plastic cover with the tweezers.
    • You should now see the battery compartment.
  4. Casio MTD-120 Battery Replacement: passo 4, imagem 1 %32
    • Remove the battery with the tweezers.
    • Use your fingers to remove the battery if you find it difficult using the tweezers.
  5. Casio MTD-120 Battery Replacement: passo 5, imagem 1 %32
    • Insert the new battery by pushing down gently.
    • The battery needed for this watch is an SR920SW.
    • Recycle the old battery.
    • Where To Recycle Batteries
  6. Casio MTD-120 Battery Replacement: passo 6, imagem 1 %32 Casio MTD-120 Battery Replacement: passo 6, imagem 2 %32
    • Place the plastic cover back over battery compartment.
    • Align the marked area of the plastic cover with the crown of the watch.
    • The crown is the knob that is used to set the watch.
  7. Casio MTD-120 Battery Replacement: passo 7, imagem 1 %32
    • Put the cover back and tighten it shut by pressing on it.
Conclusão
Follow the link provided in step 5 to find more information on recycling your old batteries.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 42
Duração total: 4,544
