Ir para o conteúdo principal
Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement
O que você precisa
  1. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Battery: passo 1, imagem 1 %32
    • Slide the slider on the back of the phone to the free position.
  2. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: passo 2, imagem 1 %32
    • Using a plastic opening tool, gently lift open the back panel from bottom of the panel.
  3. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: passo 3, imagem 1 %32 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: passo 3, imagem 2 %32
    • Pull the white battery tab upwards and remove the battery.
  4. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Motherboard: passo 4, imagem 1 %32
    • Remove the four 6mm Y0 screws from the corners of the device.
  5. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: passo 5, imagem 1 %32
    • Remove the four 5mm Y0 screws from the back of the device.
  6. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: passo 6, imagem 1 %32
    • Using a spudger, pry away the motherboard from its compartment, by inserting the spudger in the compartment and lifting upwards until fully out.
  7. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: passo 7, imagem 1 %32
    • Lastly, using your hands, separate the motherboard from its compartment.
  8. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: passo 8, imagem 1 %32 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: passo 8, imagem 2 %32 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement, Camera: passo 8, imagem 3 %32
    • Using a spudger, gently lift up the orange connector.
  9. Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: passo 9, imagem 1 %32 Casio G'zOne Commando Verizon MIL-SPEC Camera Replacement: passo 9, imagem 2 %32
    • Flip over the motherboard
    • Using a spudger, lift up the small black connector and remove the camera.
Conclusão
Zack Almeida
Membro desde: 10/24/18
392 Reputação
Autoria de 4 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 59
Ao todo: 361
