Introdução
To replace a SIM card, you will have to remove the battery. Once you remove the battery, you will be able to easily insert the SIM card.
O que você precisa
In order to get at the battery, you will have to pull the locking tab to the “Free” position. Once you do that you will have to pry the battery cover off (using a plastic opening tool or similar prying tool). Because the phone is designed to be waterproof, it is advised that you do NOT use your fingernails.
After removing the battery you will find a port that is labeled SIM directly beneath where the battery was sitting.
3 outras pessoas executaram este guia.
2 comentários
My Casio C811 will not go to a browser, keeps saying no network connection. I am in an area that I have had connection with no problems before. The phone did some sort of reset on it own and now wont access any browser, google, Facebook ect. I have check the network setting and they appear OK. Any suggestions
