Ir para o conteúdo principal
Casio G’zOne Commando 4G LTE Motherboard Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. Casio G’zOne Commando 4G LTE Motherboard Replacement, Open back cover.: passo 1, imagem 1 %32
    • This device is waterproof and well sealed, so it is difficult to open this handset.
    • Start by opening the cover of the handset.
    • Do not use your nails to open the cover. Use the iFixit Opening Tool (refer to the image).
  2. Casio G’zOne Commando 4G LTE Motherboard Replacement, Free and remove the battery: passo 2, imagem 1 %32 Casio G’zOne Commando 4G LTE Motherboard Replacement, Free and remove the battery: passo 2, imagem 2 %32
    • Move the orange tab to the right side to take out the battery.
    • Remove the battery.
  3. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove front and back screws: passo 3, imagem 1 %32 Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove front and back screws: passo 3, imagem 2 %32
    • Using the Phillips #00 screwdriver remove the front and back 5.0 mm screws as shown in the picture.
    • There are four screws in the back and two screws in the front.
  4. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: passo 4, imagem 1 %32 Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: passo 4, imagem 2 %32 Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove side-Back cover: passo 4, imagem 3 %32
    • Gently remove the side cover from the phone by lifting up on the corners as shown in the picture.
    • Press down on the screen to help remove the plastic side cover from the phone.
    • Make sure to push gently because the frame is fragile.
  5. Casio G’zOne Commando 4G LTE Motherboard Replacement, Remove Side-Front cover: passo 5, imagem 1 %32
    • Pull the side front cover off the face of the phone.
  6. Casio G’zOne Commando 4G LTE Motherboard Replacement: passo 6, imagem 1 %32 Casio G’zOne Commando 4G LTE Motherboard Replacement: passo 6, imagem 2 %32 Casio G’zOne Commando 4G LTE Motherboard Replacement: passo 6, imagem 3 %32
    • Remove the eight 2.5mm Phillips #00 screws in the holes of the casing.
  7. Casio G’zOne Commando 4G LTE Motherboard Replacement: passo 7, imagem 1 %32
    • Gently pull off the motherboard cover.
  8. Casio G’zOne Commando 4G LTE Motherboard Replacement: passo 8, imagem 1 %32
    • Using the Phillips #00, remove all 2.5 mm screws attached to the motherboard.
    • Do not touch the integrated circuits in the motherboard.
  9. Casio G’zOne Commando 4G LTE Motherboard Replacement, Motherboard: passo 9, imagem 1 %32 Casio G’zOne Commando 4G LTE Motherboard Replacement, Motherboard: passo 9, imagem 2 %32
    • Gently remove the motherboard with the spudger.
Conclusão
4 outras pessoas executaram este guia.
Brett Boehm
Membro desde: 09/25/14
281 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-5, Brown Fall 2014 Membro de USF Tampa, Team 1-5, Brown Fall 2014
USFT-BROWN-F14S1G5
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 9
Duração total: 876
