Ir para o conteúdo principal
Casio G’zOne Commando 4G LTE Battery Replacement
O que você precisa
  1. Casio G’zOne Commando 4G LTE Battery Replacement, Battery: passo 1, imagem 1 %32
    • In order to get at the battery, you will have to pull the locking tab to the “Free” position. Once you do that you will have to pry the battery cover off (using a plastic opening tool or similar prying tool). Because the phone is designed to be waterproof, it is advised that you do NOT use your fingernails.
  2. Casio G’zOne Commando 4G LTE Battery Replacement: passo 2, imagem 1 %32 Casio G’zOne Commando 4G LTE Battery Replacement: passo 2, imagem 2 %32
    • Once the battery cover is off, there is another lock holding the battery in place. However, with this lock all you have to do is slide the lock to “Free”, and pull the battery out by lifting it from the bottom side (the side with the orange lock).
Conclusão
To install a new battery in your device, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Daniel Keenan
Membro desde: 10/28/15
374 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 1-9, Miles Fall 2015 Membro de UMass Dartmouth, Team 1-9, Miles Fall 2015
UMASSD-MILES-F15S1G9
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 5
Últimos 30 dias: 15
Duração total: 746
