Introdução
The Casio FX-991EX can malfunction if the battery is discharged, even with solar power. Thankfully, replacing it is a simple job.
O que você precisa
Remove the battery cover's screw using a Philips #0 screwdriver.
Slot the new battery into the compartment. Ensure that the positive side (with writing) faces up...
And the negative side faces the calculator's screen.
If you need to reset the calculator after this, it's SHIFT+9 > 3 > =.
Otherwise, you're ready to crunch numbers again!
