Ir para o conteúdo principal
Casio FX-991ES Plus Battery Replacement
O que você precisa
  1. Casio FX-991ES Plus Battery Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the calculator is off. If not, turn it off by pressing the [Shift] button then the [AC] [OFF] button.
  2. Casio FX-991ES Plus Battery Replacement: passo 2, imagem 1 %32
    • Flip the calculator upside down and lay it on a flat surface.
    • Do not press hard on the calculator to avoid turning it on by mistake.
  3. Casio FX-991ES Plus Battery Replacement: passo 3, imagem 1 %32 Casio FX-991ES Plus Battery Replacement: passo 3, imagem 2 %32
    • Use a Phillips #0 screwdriver to unscrew the 1.6 mm screw on the battery cover.
    • Remove the battery cover.
    • Be gentle while unscrewing the cover, to avoid damaging it.
  4. Casio FX-991ES Plus Battery Replacement: passo 4, imagem 1 %32 Casio FX-991ES Plus Battery Replacement: passo 4, imagem 2 %32 Casio FX-991ES Plus Battery Replacement: passo 4, imagem 3 %32
    • Use a spudger to remove the old battery. Insert it in the empty slot to pry out the battery.
    • Do not use a sharp item like a knife.
    • Do not use metal tools, to avoid damaging parts of the battery compartment.
  5. Casio FX-991ES Plus Battery Replacement: passo 5, imagem 1 %32
    • Place the new battery into the compartment with the positive (+) side facing upwards.
  6. Casio FX-991ES Plus Battery Replacement: passo 6, imagem 1 %32
    • Attach the battery cover and tighten the screw with a Phillips #0 screwdriver.
  7. Casio FX-991ES Plus Battery Replacement: passo 7, imagem 1 %32
    • To reset the calculator, press the [ON] button.
    • Press the [SHIFT] button.
    • Press the [9] [CLR] button to clear the data.
    • Press the [3] button to choose "ALL".
    • Press the [=] button to agree.
    • Press the [AC] button
Linha de Chegada
20 outras pessoas executaram este guia.
Zinab Alhamoud
Membro desde: 01/17/21
679 Reputação
Autoria de 1 guia
Equipe
6Comentários do guia
Thank you so much! God bless you.
Igor Diniz - Responder
Can you send me one please
In Jaigaon india
chandra giri - Responder
La touche ON de ma calculatrice ne fonctionne plus comment faire ?
Emmanuel Prosper - Responder
Merci du fond du cœur 🫶🫶🫶
Malik Guellour - Responder
Comentar
Visualizações:
Últimas 24 horas: 43
Últimos 7 dias: 252
Últimos 30 dias: 1,243
Ao todo: 82,808
