Ir para o conteúdo principal
Casio FX-115MS Motherboard and Screen Replacement
O que você precisa
  1. Casio FX-115MS Motherboard and Screen Replacement, Back Plate: passo 1, imagem 1 %32
    • Remove the 6 screws, which are 5mm long, using a PH1 screwdriver.
  2. Casio FX-115MS Motherboard and Screen Replacement: passo 2, imagem 1 %32 Casio FX-115MS Motherboard and Screen Replacement: passo 2, imagem 2 %32 Casio FX-115MS Motherboard and Screen Replacement: passo 2, imagem 3 %32
    • Use plastic spudger to separate backplate from the front-plate. Place the flat end of the spudger in the seam between the front and back, near one end of the calculator. Then slide the spudger towards the calculator's center. The two sides will pop free from each other as you go through it with the spudger.
  3. Casio FX-115MS Motherboard and Screen Replacement, Battery: passo 3, imagem 1 %32 Casio FX-115MS Motherboard and Screen Replacement, Battery: passo 3, imagem 2 %32
    • Using the pointed end of the nylon spudger, carefully pry an edge of the battery, and lift the battery from its socket.
  4. Casio FX-115MS Motherboard and Screen Replacement, Motherboard and Screen: passo 4, imagem 1 %32 Casio FX-115MS Motherboard and Screen Replacement, Motherboard and Screen: passo 4, imagem 2 %32
    • Using the plastic spudger, carefully pry the battery terminals from the front plate. If the plastic spudger is too weak for prying out the terminals, use the small metal spudger.By Carefully bending and/or prying the little teeth on the terminals upwards you can easily remove them.
  5. Casio FX-115MS Motherboard and Screen Replacement: passo 5, imagem 1 %32 Casio FX-115MS Motherboard and Screen Replacement: passo 5, imagem 2 %32 Casio FX-115MS Motherboard and Screen Replacement: passo 5, imagem 3 %32
    • Using the small metal spudger. Carefully pry around the edge of the solar panel until it becomes loose. Then simply pull it from its socket using your hands.
  6. Casio FX-115MS Motherboard and Screen Replacement: passo 6, imagem 1 %32 Casio FX-115MS Motherboard and Screen Replacement: passo 6, imagem 2 %32
    • Using a PH0 phillips screwdriver, unscrew the four, 4mm, pan head screws from the motherboard.
  7. Casio FX-115MS Motherboard and Screen Replacement: passo 7, imagem 1 %32 Casio FX-115MS Motherboard and Screen Replacement: passo 7, imagem 2 %32 Casio FX-115MS Motherboard and Screen Replacement: passo 7, imagem 3 %32
    • Carefully lift the motherboard, screen, solar panel, and battery terminal combination from the front plate. Start from the motherboard and lift at an angle toward the solar panel.
Conclusão
9 outras pessoas executaram este guia.
Lindsey Griffin
Membro desde: 10/04/16
472 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 2-2, Nance Fall 2016 Membro de USF Tampa, Team 2-2, Nance Fall 2016
USFT-NANCE-F16S2G2
4 Membros
Autoria de 15 guias
1Comentário do guia
where can i find an lcd for this exact calculator?
Ahmad Alsabbagh - Responder
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 65
Ao todo: 3,959
