Ir para o conteúdo principal
Casio FX-115ES PLUS Battery Replacement
O que você precisa
  1. Casio FX-115ES PLUS Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn off the calculator by pressing the [shift] button.
    • Press the [AC] [OFF] button to turn off the calculator by pressing the [shift] button.
  2. Casio FX-115ES PLUS Battery Replacement: passo 2, imagem 1 %32 Casio FX-115ES PLUS Battery Replacement: passo 2, imagem 2 %32 Casio FX-115ES PLUS Battery Replacement: passo 2, imagem 3 %32
    • Turn the calculator the other way around so that the small panel in the top right corner of the back of the calculator faces forward.
    • Use a Phillips #0 screwdriver to remove the screw in the upper right corner.
    • Don't force the screwdriver on the screw, as it can strip the screw
  3. Casio FX-115ES PLUS Battery Replacement: passo 3, imagem 1 %32
    • Remove the battery cover.
  4. Casio FX-115ES PLUS Battery Replacement: passo 4, imagem 1 %32
    • Insert the spudger in the available slot in the middle of the right side.
    • Use the spudger to take the battery out carefully.
    • Be careful when removing the battery to avoid any damage.
  5. Casio FX-115ES PLUS Battery Replacement: passo 5, imagem 1 %32
    • Place the new 357 oxide button battery into the calculator.
    • Make sure that the + sign is at the bottom.
  6. Casio FX-115ES PLUS Battery Replacement: passo 6, imagem 1 %32 Casio FX-115ES PLUS Battery Replacement: passo 6, imagem 2 %32 Casio FX-115ES PLUS Battery Replacement: passo 6, imagem 3 %32
    • Reattach the battery cover.
    • Insert the screw back in place along with the cover using a Phillips #0 screwdriver.
    • Make sure to turn the screwdriver clockwise to lock the screw in tight, preventing the battery from falling out.
  7. Casio FX-115ES PLUS Battery Replacement: passo 7, imagem 1 %32
    • Reset the calculator by pressing [ON].
    • Press the [Shift] button.
    • Press the [9] [CLR] button to clear the data.
    • Press the [3] [ALL] button option.
    • Press the [=] [yes] button to accept.
    • Press the [AC] key to reset completely.
Conclusão
You have successfully replaced a Casio FX-115ES PLUS battery
Rodrigo Lopez
Membro desde: 01/23/23
145 Reputação
Autoria de 1 guia
Equipe
CSU Los Angeles, Team 2-1, Briggs Spring 2023 Membro de CSU Los Angeles, Team 2-1, Briggs Spring 2023
CSULA-BRIGGS-S23S2G1
Membros da 2
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 20
Últimos 30 dias: 100
Duração total: 1,510
