Introdução
This guide is a step-by-step process on how to replace the zoom lens on a Casio Exilim EX-Z850 camera. This will help you replace it if it is broken or damaged, and there are no special skills required for this project.
O que você precisa
Carefully remove the L shaped frame from the camera.
At the bottom of the camera the L shaped frame is being held in by two plastic bumps and a metal tab. Pop the frame off the bumps and tabs.
There is a yellow and orange wire soldered onto the camera. Be careful not to pull them off.
Remove the frame on the back side of the camera where the LCD screen was.
With the screwdriver, remove the two screws connecting the frame with the camera
Slowly pry off the frame from the camera
After removing the frame a plastic piece with two yellow button connections should fall off.
To put the Casio Exilim EX-Z850 camera back together, reserve the instructions to follow them in a backward manner.
