Ir para o conteúdo principal
Casio Exilim EX-Z850 Motherboard Replacement
O que você precisa
  1. Casio Exilim EX-Z850 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Using the Phillips #00 screwdriver, remove the four screws from the side of the speaker.
  2. Casio Exilim EX-Z850 Motherboard Replacement: passo 2, imagem 1 %32
    • Using the Phillips #00 screwdriver, remove the four long screws from the bottom of the camera.
    • When reassembling the camera, the longer screws go on the bottom of the camera.
  3. Casio Exilim EX-Z850 Motherboard Replacement: passo 3, imagem 1 %32
    • Using the Phillips #00 screwdriver, remove the four screws from the side opposite of the speaker.
  4. Casio Exilim EX-Z850 Motherboard Replacement: passo 4, imagem 1 %32 Casio Exilim EX-Z850 Motherboard Replacement: passo 4, imagem 2 %32 Casio Exilim EX-Z850 Motherboard Replacement: passo 4, imagem 3 %32
    • Pry open bottom casing gently after all screws have been removed.
    • With tweezers, carefully remove the ribbon from the LCD screen.
    • Set the bottom casing aside.
  5. Casio Exilim EX-Z850 Motherboard Replacement: passo 5, imagem 1 %32 Casio Exilim EX-Z850 Motherboard Replacement: passo 5, imagem 2 %32 Casio Exilim EX-Z850 Motherboard Replacement: passo 5, imagem 3 %32
    • Pry apart the top casing using tweezers.
    • Set the top casing aside.
    • The bottom left screw on the board is orange and the longest screw.
  6. Casio Exilim EX-Z850 Motherboard Replacement: passo 6, imagem 1 %32 Casio Exilim EX-Z850 Motherboard Replacement: passo 6, imagem 2 %32
    • Carefully remove the pieces of black tape on the bottom of the LCD screen that attach it to the frame.
    • Use tweezers to pry the LCD screen off from the opening.
  7. Casio Exilim EX-Z850 Motherboard Replacement: passo 7, imagem 1 %32 Casio Exilim EX-Z850 Motherboard Replacement: passo 7, imagem 2 %32
    • Lift the LCD screen and move it to the other side.
  8. Casio Exilim EX-Z850 Motherboard Replacement: passo 8, imagem 1 %32 Casio Exilim EX-Z850 Motherboard Replacement: passo 8, imagem 2 %32
    • Using a pair of tweezers, pry off the LCD casing.
  9. Casio Exilim EX-Z850 Motherboard Replacement: passo 9, imagem 1 %32 Casio Exilim EX-Z850 Motherboard Replacement: passo 9, imagem 2 %32 Casio Exilim EX-Z850 Motherboard Replacement: passo 9, imagem 3 %32
    • Flip open the connector holding the ribbon.
    • Use the tweezers to carefully pull out the LCD screen with the ribbon from the camera.
  10. Casio Exilim EX-Z850 Motherboard Replacement: passo 10, imagem 1 %32 Casio Exilim EX-Z850 Motherboard Replacement: passo 10, imagem 2 %32
    • Using the Phillips #00 screwdriver, remove two screws on the side where the battery is located.
    • Remove the lanyard loop after the screws come off.
    • Pull the side casing so it becomes dislocated from the top of the camera frame.
  11. Casio Exilim EX-Z850 Motherboard Replacement: passo 11, imagem 1 %32 Casio Exilim EX-Z850 Motherboard Replacement: passo 11, imagem 2 %32
    • On the front of the camera near the flash, flip the connector holding the ribbon.
    • Remove the ribbon from the connector.
  12. Casio Exilim EX-Z850 Motherboard Replacement: passo 12, imagem 1 %32 Casio Exilim EX-Z850 Motherboard Replacement: passo 12, imagem 2 %32 Casio Exilim EX-Z850 Motherboard Replacement: passo 12, imagem 3 %32
    • Carefully remove the L-shaped frame from the camera.
    • The L shaped frame is being held in by two plastic bumps and a metal tab at the bottom of the camera.
    • Pop the frame off the bumps and tabs.
    • Potential for device damage: Be careful not to pull off the yellow and orange wire soldered onto the camera.
  13. Casio Exilim EX-Z850 Motherboard Replacement: passo 13, imagem 1 %32 Casio Exilim EX-Z850 Motherboard Replacement: passo 13, imagem 2 %32
    • Flip the connector and remove the ribbon cable from the motherboard next to the lens.
  14. Casio Exilim EX-Z850 Motherboard Replacement: passo 14, imagem 1 %32 Casio Exilim EX-Z850 Motherboard Replacement: passo 14, imagem 2 %32
    • Remove the frame on the back side of the camera where the LCD screen was.
    • Use the Phillips #00 screwdriver to remove the two screws connecting the frame to the camera.
    • Slowly pry off the frame from the camera.
    • After removing the frame, a plastic piece with two yellow buttons should fall off.
    • Do not pull the plastic piece off as it is soldered to two wires: a yellow and orange one.
  15. Casio Exilim EX-Z850 Motherboard Replacement: passo 15, imagem 1 %32
    • On the back of the camera where the LCD screen was, remove the 3 screws located behind the lens using the Phillips #00 screwdriver.
  16. Casio Exilim EX-Z850 Motherboard Replacement: passo 16, imagem 1 %32
    • Remove the large orange ribbon previously held in by screws from the camera.
  17. Casio Exilim EX-Z850 Motherboard Replacement: passo 17, imagem 1 %32
    • On the backside of the camera where the indicator lamp is located, remove the two screws using the Phillips #00 screwdriver.
  18. Casio Exilim EX-Z850 Motherboard Replacement: passo 18, imagem 1 %32 Casio Exilim EX-Z850 Motherboard Replacement: passo 18, imagem 2 %32 Casio Exilim EX-Z850 Motherboard Replacement: passo 18, imagem 3 %32
    • On the front side of the indicator lamp remove the screw using the Phillips #00 screwdriver.
  19. Casio Exilim EX-Z850 Motherboard Replacement: passo 19, imagem 1 %32 Casio Exilim EX-Z850 Motherboard Replacement: passo 19, imagem 2 %32
    • Desolder the lens from the motherboard.
    • Desolder the wire from the motherboard.
    • The motherboard is now detached from the rest of the camera.
Conclusão
Uma outra pessoa concluiu este guia.
Jennifer Roth
Membro desde: 01/28/11
162 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 4-38, Regan Winter 2011 Membro de Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
Membros da 4
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 3,826
